30ton/1600 hydraulic press brake machine
Postby zihuanew » Wed Jan 11, 2017 9:28 am
CE certificate 125 ton hydraulic press brake. Bending jobs programmable. Front support easy operated ad. 30ton 1600 press brake machinery simple to operate.
cnc hydraulic press brake iron sheet bending machine WC67Y- 30Ton/ 1600mm WC67Y-30T/1600; Machine Type: Press Brake; Raw Material: Sheet / Plate
cnc bending machine for kitchen appliance in south africa
188 products China 30 Ton Hydraulic Press Brake - Select high quality 30 Ton Hydraulic Press Brake 30t/1600 1mm Sheet Metal Bending Machine Bend 2mm
30T/1600 small hydraulic press brake machine,US $ 3000 - 3500 / Set, New, Anhui, China (Mainland), SXZG.Source from Anhui Sanxin Heavy Industry
APT International is specialised in buying and selling used Hydraulic press brakes. Our machines; »; Press brakes, Bending machines, Straightening machines,. . Trumpf Trumaform 400, 30 ton x 430 mmStocknumber: O.01 8143 middot; Trumpf
Used Press Brake Machine, Hydraulic, Mechanical, CNC, Metal Folder, Machinery, Pressco2 laser cutting machine in peru for toyses, fabricating equipment, Brakes, Box and Pan, Hand, Leaf, Power,
Condition: New. Place of Origin: Anhui China (Mainland). Brand Name: SXZG. Model Number: WC67K-30T/1600. Machine Type: Press Brake. Raw Material
30Ton/1600 Hydraulic Press Brake Machine, You can get more details about Hydraulic Press Brake,Hydraulic Press Brake,Hydraulic Press Brake from mobile
Price Of Small Manual Sheet Bending Machine Hydraulic Press Brake. Nantong WF67K 30Ton/ 1600 Cnc Servo Small Hydraulic Plate Press Brake.
Quality CNC Tandem Press Brake manufacturers amp; exporter - buy Hydraulic Hydraulic Tandem CNC Sheet metal brake bending machine 30 ton - 400 ton . WC67Y-160/3200, 1600, 3200, 2650, 320, 200, 60, 8, 50, 480, 11, 280, 9500.
excellent quality new coming flat ironworker bending
zihuanew Offline
Users browsing this forum: No registered users and 11 guests
