More fashion trends and style tips
Postby DebbieN » Mon Jul 10, 2017 1:03 pm
The adidas superstar homme pas cher sees the micro-perf uppers come in a choice of two tonal finishes.The uppers come in a choice of Clean Aqua or Chalk White, with the addition of micro-perforations across the base layer providing a touch of class and detail. The Three Stripes, heel panel and lacestay panel are finished in a matching suede, whilst the Shell Toe and sole unit are both finished in a slightly brighter shade, which continues on to the lining and laces. To round things off the traditional branding is debossed onto the tongue, heel and lateral side. Clean and simple seems to be the theme of the season, which we are definitely not complaining about with results this good.
</br></br>
The adidas superstar femme pas cher sees the iconic model sport another new update on the upper section.As we said when we introduced the Primeknit versions (which you can view here), the word ‘iconic’ can sometimes be used incorrectly, but in the case of the SUPERSTAR, that is definitely not the case – and this year the shoe is having a big year. The traditional leather upper is replaced by a no-sew WOVEN one, which for this first release sees a mix of Core Black and Running White in a style that mimics the outline of panels on the original design. To give the shoe more familiarity, the shell toe and sole unit add some contrast in a clean white finish. There’s no argument that the SUPERSTAR is a classic shoe and sometimes messing with a classic isn’t the right thing to do but, like the Primeknit versions, this is another perfect example of things being done correctly.
</br></br>
The adidas tubular radial pas cher is comprised of a trio of relatively muted colourways, with just a small pop of colour.The first of the three is dominated by a mix of FTWR White and Core Black, with matching Vintage White cage and Core Black heel strap, whilst a hit of magenta on the heel tab provides the pop. The second goes instead with a combination of Mineral and Black, with the Mineral continuing on to the cage, whilst the heel strap is finished in Night Navy and the pop comes from the hit of cyan on the heel tab. The last is the stealthiest of the three with a mix of Shadow Black and Core black across the upper, cage and heel strap, with a subtle hit of Future Forest on the heel tab. All three pairs sit on white sole units, with coloured detailing along the top edge to tie in with the upper. Hats off to ADIDAS as the TUBULAR range continues to go from strength to strength.
</br></br>
The adidas nmd r1 soldes sees the model that was introduced late last year already get an undated upper.The lightweight PRIMEKNIT upper features an all-over noise style graphic in shades of grey, with black accents on the lace eyelets, ankle collar, heel detailing and strap, which features ‘The Brand With The Three Stripes’ branding in white. Down below is the Boost midsole, in its traditional white finish, with additional hits of black on the midsole supports and outsole rounding things off. When it comes to big launches the NMD easily took the prize in 2015 and it certainly managed to cause a stir, which looks like it will continue well into this year with this updated model.
DebbieN Offline
Users browsing this forum: No registered users and 16 guests
