What a absolute way to install Din571 Concrete Nails
รวมรูปรถจากเพื่อนๆสมาชิกทั่วไทย...
Postby BackSmith » Thu Jun 22, 2017 10:41 am
Well I achievement this cavalcade has been helpful! If you ran into a agnate torn screw problem, let me apperceive what you concluded up accomplishing in the comments. This adjustment works, but is apathetic and apparently not best for Concrete Nails .
You apperceive there's a absolute way to install woodscrews, right? If abutting two pieces of wood, a cast aperture should be accomplished through the workpiece you're adhering to addition piece. This aperture is sized so that the screw accoutrement canyon through afterwards grabbing. This prevents the workpiece from "jacking up" if active the screw. You apperceive what I beggarly — you've had it happen. And if this happens, there's about a gap amid the workpieces no amount how bound you drive the screw.
When band two pieces of hardwood, predrill a pilot hole.
Use as continued a screw as you can afterwards dabbling through the aback ancillary of the abutting piece.
When appliance a flathead screw, use a screwdriver bit not more than the screw arch or you will mar your work. A bit that is too attenuated may band your screw head.
If you will screw into harder woods, use a superior Spax or aberrant screw – torn screws will alone accomplish you sad.
Dowel Screw: for adhering knobs, or abutting two board poles together. There are appropriate drivers for these, or you can use carnality grips.
Hanger Bolt: aswell for adhering knobs, but aswell bun feet, and annihilation threaded.
Double Head Screw : accessible versions are alleged cup hooks. Hang all sorts of stuff… what abroad can I say.
BackSmith Offline
Return to Member's car & photo
Users browsing this forum: No registered users and 23 guests
